DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Building & Construction (https://www.diychatroom.com/f19/)
-   -   Deck as impervious surface (https://www.diychatroom.com/f19/deck-impervious-surface-557090/)
barnesec 10-22-2017 10:09 PM
Having difficulty getting the county to approve a deck as my subdivision's rated for 22% of the lot as impervious surface. Well I'm already at 23% or so and they're counting the proposed deck (no roof, etc.) as additional impervious surface. I'm arguing it's not. There's gaps between the decking. Ground underneath will still be absorbing water as normal. Anyone else run into this issue?
de-nagorg 10-22-2017 10:20 PM
Re: Deck as impervious surface
You may end up hiring a lawyer to argue your point, but I would get exact explanation from the code officer.
Sometimes they convince themselves that you are right when trying to explain.
Besides often they are confused and just say no before thinking it out.
You are correct a proper built deck with spaced planks is not impervious, might have a slight pooling problem though, unless you plan a proper drainage.
ED
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
