Deck Hardware - Beam To Footing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-17-2008, 03:07 PM   #1
Question
Deck Hardware - beam to footing
Howdy,
I'm planning a low-profile deck, about 18" from surface to grade. I've seen plans that involve setting beams directly in anchors set into the concrete footings. However, I can't find any anchors that would work... only ones I find are post anchors meant for a 4x4 (3.5 nominal) so a doubled 2x10 beam (total 3" nominal) wouldn't be a snug fit into the anchor. Are there anchors made specifically to set into the footings, then take a doubled 2x? beam? Anyone know where I can find that?
thanks!
Steve
plbsplbs is offline   Reply With Quote
Old 10-18-2008, 12:51 PM   #2
Just shim out the 1/2" space w/ 1/2"x4"x9" pt. (Rip a 1/2" piece off the side of a pt 4x4)
Mac
BuiltByMAC is offline   Reply With Quote
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 08:39 PM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 04:24 PM
Deck Beam connection to Post? CNJHomeowner Building & Construction 7 08-08-2008 06:14 AM
Setting a deck beam directly on footings ovahimba Building & Construction 1 01-10-2008 01:57 PM
Deck support beam has twisted Brian Ward Building & Construction 5 07-27-2007 11:03 AM
