Deck Flashing Leaking At The Corner - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-24-2010, 10:18 PM   #1
Deck Flashing Leaking at the Corner
If I spray water on the vinyl siding 10 inches above the corner of our deck, it is somehow getting behind the ledger and into the basement. It looks like it was flashed properly, but it is hard to tell with everything covered up. I've attached pictures of the deck surface and the top and bottom of the ledger. Because this in an inside corner, is there something special that they may have forget to do on the sealing of the two flashing parts that meet together in the corner (either above or below the ledger)? It could be rolling in under the bottom of the ledger, I haven't tried spraying in that area directly. I think I have to pull the vinyl off to really figure out what is going on, but it is 30 degrees out right now so the vinyl will be very brittle. Any thoughts or insight would be helpful. Thanks.
Deck Flashing Leaking at the Corner-deck_top2.jpg   Deck Flashing Leaking at the Corner-deck_top_of_ledger2.jpg   Deck Flashing Leaking at the Corner-deck_bottom_ledger2.jpg
MtnBiker is offline   Reply With Quote
Old 12-25-2010, 08:06 AM   #2
Tom Struble's Avatar
Rewards Points: 2,002
inside corners can sometimes be a problem,one of the reasons being the j channel that runs along the deck boards can channel alot of water to it
your right about the cold making the vinyl brittle,it may be a good idea to wait till the temp moderates a little,one thing you may be able to do for now is to make sure the horizontal j channel has 3/8'' drain holes drilled every 16'' or so thru the bottom [don't drill thru the flashing] which will reduce the amount of water flowing into the corner
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
MtnBiker (12-25-2010)
Ground level deck - screws or bolts? rsmith0399 Building & Construction 9 01-11-2012 12:53 PM
Deck - Header Joist Repair w/ pics DawnMarie Building & Construction 3 06-14-2010 08:25 PM
Roof leaking by Chimney, No Flashing twilightcall Roofing/Siding 2 07-30-2008 04:40 PM
Sagging concrete pool deck Immolate General DIY Discussions 1 06-11-2008 09:16 PM
Leaking flashing Colin Roofing/Siding 5 06-28-2005 07:49 AM
