Deck With A Clothesline - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-27-2018, 03:44 PM   #16
retired framer
Rewards Points: 1,274
Re: Deck with a clothesline
Two things we never do here is the split beam like the picture or notch the posts.
I would add substantial angle braces from the rim to the posts on both posts.
And I would add the angled 2x4 flat under the joists from that post back toward the house.
All the forces will be trying to rack you deck so anything that will counter that is a plus.
BTW in case you haven't noticed that they changed the treatment so now we cover the tops of joists to protect them from the crap that gets between the decking and holds water at the joists. Almost anything works, flexible flashing, tar paper or even just poly.
Rooftop deck change: why is there a leak now? stripedbass Carpentry 0 02-24-2015 04:32 PM
Pool Deck Cantilever nooneisathome Building & Construction 2 09-20-2014 10:13 PM
22x14 DECK W/ROOF SLIGHT SWAY NEED HELP FROM EXPERTS clfdpops1 Building & Construction 38 06-09-2012 07:21 PM
Building Floating Deck over ground and Concrete slab jagnew Building & Construction 2 05-27-2012 01:10 PM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 06:07 PM
