Deck Attachments - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-11-2016, 04:35 PM   #1
Rewards Points: 114
Deck attachments
Working on my deck, and trying to increase the safety and meet most codes (gonna pretend I didn't read about the beam sizes). Had a couple of questions for the board:
1. I'll be replacing some old and adding some new guard rail posts. My county requires anchor hold downs. I found the Simpson tie ones which are about $8 at the box store. Are there other brands/types that can be used? I was surprised at the cost (I know, the rail is what prevents me and my family members from falling off the deck and getting seriously injured...but $8 each?!).
2. I will be replacing the rim joist on the front. Some rail posts were just connected to that, and the overhang is too big in one section, so there is sagging and rim joist pulling off. Code calls for a continuous rim joist, but the front of the deck is 30' wide. Are multiples OK? Do I just butt the up against each other? At a joist or between joists?
Thanks again! I'm sure I'll be having many questions as I dig deeper under my deck and into codes! (Which are surprisingly enjoyable)
bcemail is offline   Reply With Quote
Rooftop deck change: why is there a leak now? stripedbass Carpentry 0 02-24-2015 04:32 PM
Pool Deck Cantilever nooneisathome Building & Construction 2 09-20-2014 10:13 PM
22x14 DECK W/ROOF SLIGHT SWAY NEED HELP FROM EXPERTS clfdpops1 Building & Construction 38 06-09-2012 07:21 PM
Building Floating Deck over ground and Concrete slab jagnew Building & Construction 2 05-27-2012 01:10 PM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 06:07 PM
