Damp Problem With A Difference - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-10-2009, 02:37 PM   #1
Damp Problem with a difference
Hi all
I've just bought a flat in an old flour mill whose walls are a barrier to a canal. There is damp on the inside wall from the floor to about 8" above the water level outside. It's beautiful but will obviously be a problem when it comes to decorating. The Walls are approx 18" thick brickwork and have been here for about 150 years. The brickwork is painted but not plastered, the bricks don't seem too moist but the cement? between them is loose to the touch. A stud wall that butts up to the brick is showing some tell tale signs of absorbing the water too. I can't drain the water so any ideas on how to address this problem?
I can provide pics if required
Superkav is offline   Reply With Quote
Old 08-10-2009, 04:54 PM   #2
Rewards Points: 582
As the property was built before 1875 its highly unlikely to have a DPC. Because the walls are next to a canal its quite likely to be suffering from rising damp. Its possible to have the walls chemically injected, but the inside would have to be sand/cement rendered with an added waterproofer/salt retarder.
stuart45 is offline   Reply With Quote
Old 08-10-2009, 05:09 PM   #3
Rewards Points: 3,622
uncertain as to the definition of ' DPC ' but if its a dampproofing coating, i'd agree,,, i'd look for soil injection next to the wall w/bentonite slurry,,, this is more art than science, tho.
Old 08-10-2009, 05:21 PM   #4
Rewards Points: 582
DPC is short for damp proof course. Its now a roll of plastic or similar that is put horizontally between 2 courses of bricks around the building about 6 inches above ground level to prevent rising damp. It used to be 2 courses of slate between the brickwork. Every property in the UK must have a DPC. I am guessing that the property is in the UK as he calls it a flat, and the brickwork is 18 inches thick. Our bricks are 9 inches long, whereas I think yours are 8 inches. Rising damp is usually only a problem in places with a very damp climate.
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Difference between door manufacturers Dcislander Building & Construction 4 02-20-2008 10:17 AM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
