Cutting A Window In Older Vinyl Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-25-2010, 07:58 PM   #1
cutting a window in older vinyl siding
Hello folks - first time posting here.
I've got a house with older, smooth vinyl siding. The clapboards are about 8" wide, white. I'm remodeling the kitchen and need to change a few of the windows, and have bought new construction windows to do them.
Usually, this wouldn't be a big deal - you remove the claps with a little hook tool, frame the window from the inside, cut the sheathing, nail in the window, tape it, replace the siding and retrim.
But in this case the siding is something I haven't seen before. Each of the clapboards seems to be brad nailed on the underside every few inches. It's got me stumped. How do I get it off so that I can reuse it again? Is it possible? I've thought about setting a straight edge against the wall and cutting the siding that way and leaving it in place, but I can see a lot of problems with this approach.
Can anybody out there give me the skinny on how to work with this kind of siding?
Much obliged to all - Chris
chill123 is offline   Reply With Quote
Old 08-25-2010, 08:02 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
pics? nyou got it right,i don't know why it was nailed thru the butt,you will have to pull those brads and remove the siding as usual
Tom Struble is offline   Reply With Quote
How to cut vinyl siding to vent bathroom fan? db_9 General DIY Discussions 9 11-13-2009 12:58 AM
emergency vinyl siding installation question!!! diy'er on LI Building & Construction 9 08-13-2009 11:16 PM
Cutting asbestos siding Marvin Gardens Building & Construction 22 12-06-2008 05:00 PM
Vinyl siding and stucco. PrairieStudent Building & Construction 4 08-29-2008 03:03 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
