Cutting Top Plate For Clearance - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-10-2016, 12:13 AM   #1
Rewards Points: 398
Cutting top plate for clearance
I'm adding central air to a small duplex. There is no attic, so I have to run the ducts in a soffit. The air handler will be in an existing small hall closet. The soffit would not have to be as low, if I can get the ducts tight against the ceiling. The top plate would be the one over the existing closet door. Do you think there would be any issues with this? I'm getting it inspected for electrical and a/c. I'm not sure if the electrical or mechanical inspector would say anything about it.
Malcolm is offline   Reply With Quote
Old 04-10-2016, 01:37 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 10,048
Re: Cutting top plate for clearance
If it's a load bearing wall, you don't want to be cutting into the top plate.
But they make HVAC ducts that can change shape....you don't have to go round.
You main problem is you won't find what you need at HD....you need to go to an HVAC duct supply house.
ddawg16 is online now   Reply With Quote
Old 04-10-2016, 11:22 AM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,578
as long as your not compromising a point load cutting through the top plate is perfectly fine.. and make sure that any joists next to it are properly fastened to the plate on either side so it doesnt want to move. its done all the time by proffesionals
woodworkbykirk is offline   Reply With Quote
Old 04-11-2016, 12:46 AM   #4
Rewards Points: 1,036
I would add, as long as it is not a bearing wall or a shear wall you will be fine.
Mingledtrash is offline   Reply With Quote
Old 04-11-2016, 06:03 AM   #5
Rewards Points: 4,814
No need to cut top plates...
ron45 is offline   Reply With Quote
Old 04-12-2016, 07:47 PM   #6
its perfectly fine to cut a top plate in a bearing wall as long as the joists closest to it are within 2" of being over top of a stud.. it wont effect anything
Should I insulate my sill plate? LVDIY Insulation 5 11-14-2015 06:44 PM
Bottom plate and notched studs miamicuse Carpentry 7 06-04-2013 09:27 PM
Rotted sole plate in bathroom firemanter Carpentry 3 05-30-2013 03:14 PM
trying to reuse sill plate studs without cutting them question Pawl Building & Construction 15 05-26-2013 02:14 PM
Cutting out bottom plate for new door in existing partition sheslostcontrol Carpentry 3 01-05-2011 08:18 AM
