Cutting Roof Trusses To Install Sky Light - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-10-2013, 11:45 PM   #1
Cutting roof trusses to install sky light
Hi buying a home in nj home inspector found that they cut several roof trusses to install sky light what can I do to repair ? How serious of an issue is this ? How much should I ask for repair? Roof also has two layers at end off useful life thanks bill
Billgran is offline   Reply With Quote
Old 10-11-2013, 12:03 AM   #2
Rewards Points: 6,652
No, you do not want to cut Roofing Trusses, especially if they are the engineered variety, manufactured on a line. You are better in using a Sun dome, to bring in light, or find a Skylight that will fit within the width between trusses.
The Following 2 Users Say Thank You to gregzoll For This Useful Post:
Billgran (10-11-2013), woodworkbykirk (12-07-2013)
Old 10-11-2013, 12:13 AM   #3
Registered User
Rewards Points: 526
As they are already cut, consult a truss manufacturing company for an estimate.
Gary
Old 10-11-2013, 12:42 AM   #4
GBrackins's Avatar
Rewards Points: 2,108
or hire a professional engineer that specializes in building construction to evaluate what you have and what is needed to fix it.
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
Gary in WA (10-11-2013)
Old 10-11-2013, 01:53 AM   #5
Residential Designer
AndyGump's Avatar
Rewards Points: 874
Send a message via Skype™ to AndyGump
As GBrackins and the other Gary have already stated, find a professional engineer to design a repair for the trusses.
I had to do this for a client here in Laguna Woods Ca. The engineer designed a fix for two cut trusses. The design costs $600.00 but it was money well spent. The solution included sandwiching the same nominal sized lumber with thru-bolts and was relatively easy for the contractor to perform.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
Old 10-11-2013, 09:17 PM   #6
Registered User
Rewards Points: 526
Oops, forgot to add; truss companies here have in-house SE's. Pay once rather than twice, you may find it a lot cheaper. Thanks, guys, for catching that!
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
GBrackins (12-05-2013)
Old 12-05-2013, 10:55 AM   #7
Do you see any manufacturer identification markings on the original rafters? If the rafters are factory-built there will likely be a company name somewhere. I would suggest contacting the manufacturer as they should have a structural engineer in house who is familiar with their products. If your house is stick built you should contact a structural engineer to can assess the current structural situation and recommend the necessary repairs.
usbp.josh is offline   Reply With Quote
Old 12-05-2013, 11:54 AM   #8
Rewards Points: 1,290
I don't know where the OP is, but here in Seattle, we have lost probably 60%+ of our truss manufacturers in the last 8 years.
Anti-wingnut is offline   Reply With Quote
The Following User Says Thank You to Anti-wingnut For This Useful Post:
Nailbags (12-07-2013)
Old 12-05-2013, 01:22 PM   #9
Rewards Points: 18,118
Not likely someone on lines going to do any thing but guess at the cost to reroof. Going to have to go local and get some quotes.
You did not add your location to your profile, there can be a huge difference in prices depending on where you live.
Thanks to someone trying to save money it's now going to cost you double to remove them and haul away.
Old 12-05-2013, 07:46 PM   #10
Number one:
Make sure the Home Inspector is right, most of them are really stupid
Old 12-06-2013, 10:35 AM   #11
Rewards Points: 3,130
Do you have multiple skylights? Very large ones? Most I've ever seen will fit between trusses or rafters that are 24 inches oc. I installed a couple of them in my house.
As others have said, you need engineering advice. Probably the most-engineered component in a house is the trusses.
Old 12-07-2013, 08:01 AM   #12
Rewards Points: 626
Try more like 75%+ I know of only two left out of the 10 that used to be on the I-5 corridor between seattle and centralia.
Nailbags is offline   Reply With Quote
Old 12-07-2013, 08:17 AM   #13
747
registered
747's Avatar
Rewards Points: 544
I want to throw in my 2 cents. You should have left things alone. I'm not a big fan of skylights.
Now structure has been messed with. You need to compensate somewhere for this.
747 is offline   Reply With Quote
Old 12-07-2013, 06:11 PM   #14
Dave Sal's Avatar
Rewards Points: 1,492
I think the OP said that he is buying a home who's previous owner cut the trusses, not him.
Dave Sal is online now   Reply With Quote
The Following User Says Thank You to Dave Sal For This Useful Post:
747 (12-07-2013)
Old 12-08-2013, 03:15 PM   #15
Rewards Points: 1,332
And he has not been back since he posted his original question 2 months ago
danpik is offline   Reply With Quote
Tags
truss roof
Decking Issue after new roof install CrankyDragon Roofing/Siding 12 07-04-2011 11:26 AM
How to install hood vent cover on flat roof? Timster Roofing/Siding 0 10-21-2010 05:04 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 10:02 AM
cutting shingles to install gutters Chicago Bill General DIY Discussions 2 02-27-2009 06:42 AM
Attic trusses and proper roof pitch Rob63 Carpentry 1 07-28-2008 04:38 AM
