Cutting A Marble Slab - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-21-2011, 09:31 AM   #1
Can marble be cut without using a wet saw?
builderB is offline   Reply With Quote
Old 10-21-2011, 09:42 AM   #2
Retired Moderator
Rewards Points: 7,174
No. Why do you ask?
Old 10-21-2011, 09:45 AM   #3
Retired Moderator
Actually you could dry cut it with a diamond blade in an angle grinder--but it's an messy cut--
Old 10-21-2011, 02:17 PM   #4
Rewards Points: 5,348
Depends on how neat a cut you need. If it's a threshold, you won't see the end cut, so not a problem. As Mike said, an angle grinder or you can use a circular saw with a diamond blade.
Ron
B. Franklin 1759
Old 10-22-2011, 12:36 PM   #5
you should be a lil more specific. Why does a wetsaw not work for you?
you could use a wet saw, grinder,skill saw, water jet, gang saw, wire saw
southshoreconst is offline   Reply With Quote
Cutting cultured marble... irishgirl77 Carpentry 6 09-19-2011 06:35 PM
Freeing a marble slab from cement bed dave11 Building & Construction 4 12-11-2010 10:00 AM
Cutting marble tile for fireplace - unsure of layout genEus Remodeling 11 04-16-2009 08:36 AM
Cutting 1/2" Marble? Bob_Alias Remodeling 1 09-07-2008 12:30 AM
