Thread Tools | Display Modes |
#1 |
Rewards Points: 28
![]() Cutting Holes Through Stucco For Vent Caps
So I've got this renovation project...
I need to cut 4 holes through the exterior wall for two new bathroom vent fans, one new kitchen exhaust hood and one new kitchen intake, all of which will be for 6 inch sheet metal duct. Exterior wall construction is 3/4" grooved "board" (which I am reluctant to call plywood as it does not look like modern plywood) covered in a traditional stucco finish (the house is over 100 years old). From my experience, there is no underlying metal/diamond lathe except where small repairs were done. Here are my questions: 1. I am assuming that I will need to cut 6-1/4" holes for a nominal 6" diameter rigid SM duct. 2. I figured that a hole saw would make the cleanest hole and I assumed that a diamond grit would be appropriate for stucco (understanding that it is similar to masonry). The problem is that I am having a hard time locating a 6-1/4" hole saw that I can chuck in a drill motor (with or without a mandrel) that has a diamond grit (the diamond grit hole saws that I am finding are for concrete coring applications). I have read that I can use carbide but they wont last as long and the holes will take much longer to cut. 3. If I use a carbide or diamond grit hole saw, once I get through the stucco and reach the wood underlayment, then what? Do I need to change to a different type of hole saw (or saw type/blade)? 4. Is there a better alternative to the hole saw approach, i.e. recip, oscillating tool, rotary cutout, etc.? Thanks in advance, all! Jimmy |
Sponsored Links | |||
Advertisement |
#2 |
Rewards Points: 100
![]() Re: Cutting Holes Through Stucco For Vent Caps
You can find a masonry hole saw 6.29 Dia. that will fit most heavy duty drills. Look for Bosch Concrete ,porcelain & Marble drill bits. Once you get through the Stucco & lath you will need to switch to wood cutting bits or blades.
Advertisement |
#3 | |
Rewards Points: 28
![]() Re: Cutting Holes Through Stucco For Vent CapsQuote:
Thanks! I went to the Bosch website but I was not able to find such a product in the size that I need. Jim |
Advertisement |
#4 | |
Rewards Points: 100
https://www.amazon.com/Agile-shop-Di.../dp/B077H33S6H |
#5 | |
Rewards Points: 28
Jimmah! |
#6 | |
retired framer
Rewards Points: 1,150
https://www.rapidtables.com/convert/...m-to-inch.html You may want to finish the hole with a jig saw.
Do not use flat bottom gables with scissor trusses. Last edited by Nealtw; 09-26-2019 at 03:14 AM. |
#7 | |
Rewards Points: 28
Thanks all! Nealtw likes this.
Advertisement |
Thread Tools | |
Display Modes | |
