DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Building & Construction (https://www.diychatroom.com/f19/)
-   -   Cutting Holes Through Stucco For Vent Caps (https://www.diychatroom.com/f19/cutting-holes-through-stucco-vent-caps-668625/)
trainguy 09-25-2019 10:44 PM
So I've got this renovation project...
I need to cut 4 holes through the exterior wall for two new bathroom vent fans, one new kitchen exhaust hood and one new kitchen intake, all of which will be for 6 inch sheet metal duct. Exterior wall construction is 3/4" grooved "board" (which I am reluctant to call plywood as it does not look like modern plywood) covered in a traditional stucco finish (the house is over 100 years old). From my experience, there is no underlying metal/diamond lathe except where small repairs were done.
Here are my questions:
1. I am assuming that I will need to cut 6-1/4" holes for a nominal 6" diameter rigid SM duct.
2. I figured that a hole saw would make the cleanest hole and I assumed that a diamond grit would be appropriate for stucco (understanding that it is similar to masonry). The problem is that I am having a hard time locating a 6-1/4" hole saw that I can chuck in a drill motor (with or without a mandrel) that has a diamond grit (the diamond grit hole saws that I am finding are for concrete coring applications). I have read that I can use carbide but they wont last as long and the holes will take much longer to cut.
3. If I use a carbide or diamond grit hole saw, once I get through the stucco and reach the wood underlayment, then what? Do I need to change to a different type of hole saw (or saw type/blade)?
4. Is there a better alternative to the hole saw approach, i.e. recip, oscillating tool, rotary cutout, etc.?
Thanks in advance, all!
Jimmy
ClarenceBauer 09-25-2019 11:07 PM
Re: Cutting Holes Through Stucco For Vent Caps
You can find a masonry hole saw 6.29 Dia. that will fit most heavy duty drills. Look for Bosch Concrete ,porcelain & Marble drill bits. Once you get through the Stucco & lath you will need to switch to wood cutting bits or blades.
trainguy 09-25-2019 11:38 PM
Clarence-
Thanks! I went to the Bosch website but I was not able to find such a product in the size that I need.
Jim
ClarenceBauer 09-25-2019 11:46 PM
Originally Posted by trainguy (Post 5942001)
Clarence-
Jim
https://www.amazon.com/Agile-shop-Di.../dp/B077H33S6H
trainguy 09-25-2019 11:58 PM
Originally Posted by ClarenceBauer (Post 5942005)
Thanks, Clarence! Not a Bosch product but the correct size and type nonetheless!
Jimmah!
Nealtw 09-26-2019 03:03 AM
Jimmah!
His link goes to 160 mm, that is 6.29 inches????
https://www.rapidtables.com/convert/...m-to-inch.html
You may want to finish the hole with a jig saw.
trainguy 09-26-2019 11:51 PM
Neal, you are absolutely correct. The diameter is fine, I just mentioned that it wasn't a Bosch product, that's all. The one that Clarence linked to is $19. Considering that these four holes will probably be the only four that I cut through stucco in my house, if that sucker makes it, it was worth every penny less than what the Bosch version would have cost!
Thanks all!
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
