.....cutting Fiber Glass Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-03-2009, 08:40 PM   #1
.....cutting fiber glass insulation
How would you cut the fiberglass insulation if it had to be cut on an angle?
I wanted it to be the same angle to parallel the pitch of the roof so it does not block air flow from the new soffit vents I just installed all around the house.
I thought about purchasing a wavy edge knife from a home store but didn't feel it was long enough or would cut nice and smooth. I also have a 30 year old pair of 12" long scissors that belonged to my Dad but they may not be the sharpest.
Speedball is offline   Reply With Quote
Old 06-03-2009, 08:49 PM   #2
yummy mummy's Avatar
Rewards Points: 1,016
Use a 2X4 and a very sharp knife.
yummy mummy is offline   Reply With Quote
Old 06-03-2009, 09:09 PM   #3
Yup, piece of wood to flatten it down & a sharp utility knife
Take care at each side where the paper is folded over
Old 06-04-2009, 04:58 AM   #4
the Musigician
DangerMouse's Avatar
if i understand right, the knives won't do it. trim carefully with long scissors, (if you're cutting just the insulation on a bevel.)
DM
Old 06-04-2009, 07:00 AM   #5
Mold!! Let's kill it!
Rewards Points: 2,012
That's the way I cut it. A big ol' shears that looks like it came out of a tent factory.
Old 06-04-2009, 10:02 AM   #6
RippySkippy's Avatar
It's one of the few times I like to use the Stanley snap blade knife...I don't like trying to mash the insulation to the point of cutting it with a utility knife...
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 06-04-2009, 06:47 PM   #7
Thank's.
I'll try some different techniques and see what works. Now I wonder if someone local has some new long scissors if the razor knife and 2X4 doesn't work.
Old 06-04-2009, 06:55 PM   #8
I've never had a problem with a razor knife
Old 06-05-2009, 08:57 AM   #9
SNC
Yup this is the way, a good pair of sissors works real well also
SNC is offline   Reply With Quote
Old 06-08-2009, 01:08 AM   #10
Rewards Points: 150
Non serrated hedge shears work great, Cuts like butter.
James Con is offline   Reply With Quote
Old 06-08-2009, 07:58 AM   #11
the Musigician
still confused here.... are you cutting a full piece at an angle or are you trying to trim an edge?
DM
Old 06-08-2009, 08:24 AM   #12
Rewards Points: 156
When I did my attic I added unfaced R 19. I used a bread knife and worked like a charm although the wife wasn't too happy at the time anyway until that winter when she just loved the extra warmth in the house, so all was good then
creamaster is offline   Reply With Quote
Old 06-08-2009, 12:32 PM   #13
Speedball, you want to retain full depth insulation above your top plates. To assure air flow above that you can purchase a 4' long egg crate type baffle which is stapled to the underside of the roof approx every 3 rd joist space.
A serated insulation knife or a bread knife will help with your cutting but insulation above must cover the top plate fully to insure a warm wall below and ceiling at the wall
Chemist1961 is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Taping drywall joints - fiber glass mesh or paper? RickT Painting 25 04-20-2011 09:09 PM
"Defogging" double-pane windows .... a gimmick?? alexz General DIY Discussions 133 03-10-2010 12:35 PM
Icynene Insulation vs Fiber glass insulation Oldschool Building & Construction 23 12-21-2008 04:35 PM
Cutting insulation yummy mummy Building & Construction 15 11-28-2006 08:13 PM
