Cutting Awning Tubing? - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By bob22
  • 1 Post By Yodaman
Old 05-31-2019, 02:16 PM   #1
Rewards Points: 2,516
cutting awning tubing?
I'm helping to deconstruct an awning system that looks (from memory) about 3/4" galv tubing.
What best to cut up long lengths of these: ONe of these or something else?:
Reciprocating saw with 18 tpi bimetal blades or 4.5" metal cutting diamond blade in an angle grinder?
Thanks!
bob22 is offline   Reply With Quote
Old 05-31-2019, 02:49 PM   #2
Rewards Points: 110
Re: cutting awning tubing?
I'm betting the problem you'll run into is keeping a tube frame still while cutting. So I'd try an angle cutter with a 4" disk first. You might go thru a few disks but that's what Harbor Freight is good for.
ChuckTin is offline   Reply With Quote
Old 05-31-2019, 04:54 PM   #3
Will likely take the skeleton down and cut it up on the ground so it will be easier and safer.
Johnny_inFL likes this.
Old 05-31-2019, 05:23 PM   #4
Usually Confused
lenaitch's Avatar
Rewards Points: 1,024
Assuming you are cutting it up for disposal, I would think a reciprocating saw or even a jigsaw with a fine blade would do the trick. If you are intending to make nice cuts for re-use, etc. I have an old and inexpensive wooden mitre box that I use with a hack saw for helping me make square cuts in gutters, downspouts, pvc pipe, etc.
_________________________________________
Sic Itur ad Astra
lenaitch is offline   Reply With Quote
Old 05-31-2019, 07:17 PM   #5
Property Mgt/Maint
Rewards Points: 7,658
If it's round, a tubing cutter would probably work. If not I would be packing the sawzall.
The 18 TPI sounds about right.
landfillwizard likes this.
[political signature removed]
Yodaman is online now   Reply With Quote
Old 06-03-2019, 09:32 AM   #6
Thanks all for the help.
Recip with 14 tpi bimetal blade went through pretty easily considering how heavy the tubing was.
