Cutting 6x6 - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-20-2010, 03:59 PM   #1
Rewards Points: 1,062
Question
cutting 6x6
what is normally used to cut 6x6 ? a bow saw ? or a chain saw even ? or multiple cuts with a circular saw ?
Old 09-20-2010, 04:09 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
any of the above or a beam saw:
You use what you have, if it provides an adequate cut. If not, you obtain a proper saw for the quality of cut required.
If you only have one or two and you can lay them down, a good old fashioned hand saw works just fine.
The Following User Says Thank You to nap For This Useful Post:
amakarevic (09-20-2010)
Old 09-20-2010, 05:51 PM   #3
Not so new
12penny's Avatar
Rewards Points: 522
I usually go all around with a circ saw and then finish with a recip.
12penny is offline   Reply With Quote
The Following User Says Thank You to 12penny For This Useful Post:
Old 09-20-2010, 06:09 PM   #4
Rewards Points: 334
I do the same as 12penny.Finish with a hand saw if you don't have a recip.
daveb1 is online now   Reply With Quote
The Following User Says Thank You to daveb1 For This Useful Post:
Old 09-20-2010, 07:25 PM   #5
Civil Engineer
Rewards Points: 5,246
I have a sliding miter saw, will go about 2/3 through, then you can finish by turning it over. Be careful if the 6x6 is not perfectly square that the saw does not bind and kick.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
Old 09-20-2010, 08:49 PM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 1,375
Nap, that is one saw I was always afraid of. Have you ever had a cir saw kick back on you? My crew used one but I wouldn't touch it, I used an attachment called a Prezi or something like that. It was a chainsaw like deal that mounted on the circular saw and it worked great and it was safe, it made a 12 inch cut and you could control it great.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 09-21-2010, 09:19 AM   #7
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
This is what i did with mine.
CoconutPete is offline   Reply With Quote
Old 09-21-2010, 10:40 AM   #8
the Musigician
DangerMouse's Avatar
When putting up a pole barn, there were odd sizes poking above the top perimeter beams.
A smallish Stihl chainsaw took them down to flush quite well. Po)
DM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
Cutting Duct ADKstorm HVAC 10 01-23-2011 01:30 AM
Cutting a beam flange devlin1k Building & Construction 17 02-13-2009 03:24 PM
Cutting in to baseboards? windowguy Painting 9 02-08-2009 09:20 AM
Cutting Board DaveSteel Carpentry 1 02-21-2008 09:38 AM
