Cut Doorway Bottom Plate On Concrete - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-09-2010, 11:00 AM   #1
Rewards Points: 81
Cut Doorway Bottom Plate on Concrete
I am finished framing my basement! It took me over five months but it's a great feeling to accomplish this! When I framed the walls, I ran the bottom plate continuous through my door ways. Now, how do I cut these plates out in the doorways? I know I would usually use a sawzall on a wood floor but I'm not too anxious to cut through the wood into the concrete with my sawzall blade. Is there a better way?
Thanks in advance!
OhioDon is offline   Reply With Quote
Old 12-09-2010, 11:08 AM   #2
Rewards Points: 2,712
Use an old fashioned hand saw?
bob22 is offline   Reply With Quote
Old 12-09-2010, 11:11 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,458
Ayuh,... Are ya covering the floors, so's to hide the scars from a sawzall blade,..??
If so,... Don't worry about it, sawzall blades are cheap...
Maybe carefully finish 'em off with a handsaw...
Old 12-09-2010, 11:19 AM   #4
Rewards Points: 81
I thought about my hand saw. Right now it's sharp and I'd like to keep it that way. I kind of assume to finish the last of the plate, the saw will contact the concrete thus dulling the saw...
Yes, the floors will be covered so I'm not worried about a little scarring.
Bottom plate for new interior wall 912jake Carpentry 4 09-05-2009 02:08 PM
How to secure bottom of 4 X 4 post to concrete? darsunt Building & Construction 6 08-19-2009 07:36 PM
attach bottom plate to exizting slab Constant Improvement Building & Construction 1 02-04-2009 12:36 PM
Boring holes in a load-bearing bottom plate benjamincall Building & Construction 22 01-21-2009 09:05 PM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 12:17 PM
