Curved Ceiling In Entrance Roof - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-11-2010, 01:28 PM   #1
curved ceiling in entrance roof
I'm about to build a roof over my sons new entrance staircase. Can someone please explain how to frame for a curved ceiling in this dormer? Can't find anything on line.
dadflynn is offline   Reply With Quote
Old 06-11-2010, 02:15 PM   #2
You might try a geodesic dome framing
happycamperbrat is offline   Reply With Quote
Old 06-12-2010, 05:10 PM   #3
You misunderstand. It will be a gable roof. My question was how to frame a curved vault under the roof.
Old 06-12-2010, 05:28 PM   #4
Most people (I think) will take either 2x12 & cut curves
Or use plywood & cut the curve in the plywood - 2 or 3 pieces
Then put 2x between the cut plywood to form the curve
Other option is to use very thin plywood (other) to form the curve
All depends upon what you are going to use for a finish ?
Old 06-12-2010, 06:06 PM   #5
kwikfishron's Avatar
Rewards Points: 168
There is a few ways to go about it. All I can tell you with the limited information you give is, the first step is to cut the arch on the sheathing facing the gable. After that depends on how big the thing is, especially depth. And as Scuba said, what’s the finish?
Can you post a picture of this gable?
kwikfishron is online now   Reply With Quote
Old 06-12-2010, 06:46 PM   #6
Registered User
Rewards Points: 526
A good way: http://www.finehomebuilding.com/how-...t-ceiling.aspx
Other ways: http://www.google.com/search?client=...=Google+Search
Be safe, Gary
Old 06-12-2010, 08:09 PM   #7
Thanks to all of you. You all supplied exactly what I was looking for, expecially the video. Mine will be an exterior dormer over an entryway so I'm uncertain what I'll finish it with. I may cover it with 1/4" Luan plywood first to firm up the curve and then possibly white soffit material over that.
Again, thanks for the fast responses!
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
roof venting cathedral ceiling Pete H Roofing/Siding 16 09-29-2009 03:26 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
ceiling -wet and mold(fungi) mpj111 Building & Construction 13 05-31-2008 08:11 PM
