Cultured Stone - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-15-2009, 01:46 PM   #1
cultured stone
I am looking to install cultured stone on the front of my house.I want to install it up to the bottom of the windows and finish it off with a sill and install siding above it.My problem is that I have 2 bow windows on my house and I am not sure how to finish the stone off under them. Do I bring the sill under the window or butt the sill to the sides.The windows only stick out about 9 inches so there is no support framing under them.
sourmash is offline   Reply With Quote
Old 11-15-2009, 02:37 PM   #2
Rewards Points: 5,348
Does this stone require a support base? How do you plan on adhereing it to the house? What are the plans for flashing the stone/siding interface?
The other questions can be answered later.
Ron
Old 11-15-2009, 02:45 PM   #3
Concrete & Masonry
Rewards Points: 518
The sills only get used up to (butted into) the bay/bow windows in a situation like this. You don't need to use sill under these windows as they serve as a sill themselves.
jomama45 is offline   Reply With Quote
What to do where cultured stone veneer meets grass shleppy Landscaping & Lawn Care 5 09-03-2014 06:39 PM
J-Weep / Flashing for exterior cultured stone veneer wall. Spud Building & Construction 18 08-31-2009 09:44 PM
Cultured stone issues jdrolls Building & Construction 1 06-14-2009 10:56 PM
Cultured stone around fireplace MichaelP Building & Construction 10 06-21-2008 05:38 AM
