Crossbeam In Joist Bay- Needed? (Vocab Approximated) - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-20-2013, 11:24 AM   #1
Rewards Points: 27
Crossbeam in joist bay- needed? (Vocab approximated)
I'm working on a bathroom fan install, and my wife's preferred location has a little cross piece between joists that is interfering with the duct run. I can move the fan to the other side, but I'd like to know if this piece has any critical function or if I could take it out- or even remove it and replace it about 18 inches away. Thoughts?
GerardW is offline   Reply With Quote
Old 07-20-2013, 11:33 AM   #2
kwikfishron's Avatar
Rewards Points: 172
That block is probably there as a nailer because they didn't use tongue an groove plywood for the sub-floor. If that is the case then I would not remove it.
Look down in the hole and see if there's another block like it 4' away.
kwikfishron is offline   Reply With Quote
Old 07-20-2013, 11:40 AM   #3
Rewards Points: 27
I think we have a winner! I hadn't thought of it being used to fasten the subfloor.
Interestingly, for 10' towards the run of my duct (runs towards the open attic) there are no other cleats like this, but when I looked behind me they are regularly spaced. I am guessing then that the attic subfloor doesn't have cleats like this, and they start 8ft inside the 2nd floor bedroom.
So I will be sadly informing my wife that we should move the fan.
Thanks so much for the quick response!
Old 07-20-2013, 09:11 PM   #4
Rewards Points: 18,376
Something wrong here.
If that's an attic above that someone laid plywood down on the floor for storage 2 X 4's laying flat are useless.
There also should be insulation above that ceiling.
Flat Roof: Joist Layout, Slope, & Membrane Help Needed! dutchswan0311 Roofing/Siding 10 10-28-2011 01:44 PM
Better to cut batts than scrunch them to open up space at rim joist? darlingm Insulation 2 08-30-2011 01:26 PM
Help needed with floor joist cut for toilet plumbing lb3gunny Flooring 1 02-26-2011 09:47 AM
ceiling joist size - 2x4 or 2x6 needed? bigdaddy352 Building & Construction 9 08-21-2007 01:02 AM
