Crawlspace Poly - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-12-2019, 12:47 PM   #1
Rewards Points: 236
Crawlspace Poly
What is everyone using for crawlspace poly and where are you getting it? Thanks
bluefish7 is offline   Reply With Quote
Old 01-13-2019, 01:08 AM   #2
Rewards Points: 4,330
Re: Crawlspace Poly
6 mil or thicker poly - big box stores.
stick\shift is offline   Reply With Quote
Old 01-13-2019, 01:11 AM   #3
retired framer
Rewards Points: 1,730
Re: Crawlspace Poly
Thicker is better
Old 01-13-2019, 01:50 AM   #4
Hammered Thumb
Rewards Points: 538
Re: Crawlspace Poly
Assume you referring to POLYisocyanurate foam board insulation as more people call vapor barrier "visqueen" than the few that say "POLYethylene film?"
And yes I googled the spelling of both
3onthetree is offline   Reply With Quote
Old 01-13-2019, 05:51 AM   #5
retired painter
Rewards Points: 926
Re: Crawlspace Poly
I think the term visqueen might just be used regionally. I had always heard it called visqueen when I lived further south but when I moved to tenn nobody knew what it was - they all call it plastic.
mark sr is offline   Reply With Quote
Old 01-13-2019, 06:50 AM   #6
Rewards Points: 7,124
Re: Crawlspace Poly
LOL, so we will have to wait for the op to clarify whether he is insulating the crawlspace walls or covering the soil with a vapor barrier.
bluefish, your climate region (or nearest big city) added to your profile also helps.
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is online now   Reply With Quote
Old 01-13-2019, 03:47 PM   #7
Rewards Points: 236
Re: Crawlspace Poly
Thanks! Sorry I'm in Atlanta so meant ground vapor barrier
Condensation in crawlspace... pasalott Building & Construction 2 07-18-2017 07:10 PM
Crawlspace Encapsulation / Basement Vents and Registers Anomaly0 HVAC 0 06-13-2016 02:41 PM
Crawlspace treatment for older home? Pittsville Building & Construction 3 06-02-2014 10:28 PM
Crawlspace Moisture - Serious Problem PaoloM General DIY Discussions 11 12-15-2009 02:35 PM
crawlspace exposed to outside and damp djbauda Building & Construction 5 07-30-2007 08:49 AM
