Cracks On The Patio Slab - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-19-2010, 03:02 PM   #16
Rewards Points: 394
Originally Posted by itsreallyconc View Post
apron stores also carry 100% silicone in tubes,,, we seal hgwy jnts w/that stuff rather'n sika,,, use the sika sl or ns ( self-leveling / non-sag ) over backer rod,,, READ how to do it, too,,, depth:width ratio's very important - do it wrong & you'll cause mtl failure,,, cleanliness is prime consideration,,, is using ns, you must ' tool ' the jnt/crk !
Can I use this baker rod both for gaps and cracks ?
cprao is offline   Reply With Quote
Old 02-19-2010, 05:15 PM   #17
Rewards Points: 3,620
of COURSE you can,,, after all, its YOUR house, right ?
backer rod's used to give the sealant shape factor,,, sealants're designed for adhesion of TWO sides, NOT 3 ( the bottom ),,, that's why the suggestion to READ the w-site !
stadry is online now   Reply With Quote
Old 02-19-2010, 06:29 PM   #18
Civil Engineer
Rewards Points: 5,246
Not sure I understand the big box list of applicable items. You don't have plaster, so number 1 is out. As for Quikcrete, that is simply concrete, and since concrete is not elastic, it will certainly begin to crack almost as soon as you place it. I don't understand the difference between a "crack" and a "gap", perhaps there is some mystical distinction, but I can't fathom it, I would use a flexible sealant.
Old 02-19-2010, 11:53 PM   #19
Rewards Points: 394
Which means - Sika product, right ?
I put in Rapidset because all my walls are plaster and I need to fix them also.
Old 02-19-2010, 11:54 PM   #20
Rewards Points: 394
Thank you. It's my house as long as I pay mortage regularly..
I look for baker rods in Home depot..
Old 02-20-2010, 12:55 AM   #21
not easy to find as, so few know about it, there's little profit so why stock it ? usually comes in a plastic baggie - 25' or thereabouts,,, same rack as the sika sealants,,, alternative source's const supply house, glaziers, caulkers, hgwy jnt sealing companies.
' baker rods ' i don't know - ask julia childs
Old 02-20-2010, 01:43 AM   #22
Rewards Points: 394
Let me check it out tomorrow..
Pouring Patio Slab and Post Footings Question average_male Building & Construction 22 04-04-2016 12:13 PM
Flagstone patio - concrete slab or no? txpatioslab Building & Construction 5 04-14-2010 10:41 AM
what is the method to cut my concrete patio slab dragonfeeder23 Building & Construction 9 09-22-2009 07:07 PM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 12:17 PM
cracks in concrete slab causing home sale to fall though! help! bp13 Building & Construction 14 07-04-2007 12:32 AM
