Cracks In Fire Pit - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-31-2010, 12:00 PM   #1
Rewards Points: 42
Cracks in fire pit
I have built an outdoor fire pit/fireplace and it does great but I have two cracks in mortar joints that naturally tend to expand after heating up almost like expansion joint.
How can I repair/fix this? Iíve tried to repair with fireplace mortar but as the fire heats up it reappears.
Suggestions appreciated!
cbr549 is offline   Reply With Quote
Old 10-31-2010, 01:05 PM   #2
jlhaslip's Avatar
Rewards Points: 708
Are you using fire brick? or regular stone/rock?
The mortar can only do so much expansion by itself.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 10-31-2010, 01:12 PM   #3
Rewards Points: 42
Fire brick in the base, 4" concrete block for the sides.
it's cracking along the mortar joint though.
Old 10-31-2010, 02:28 PM   #4
jlhaslip's Avatar
Rewards Points: 708
You are dealing with a differential co-efficient of expansion in the joint between various products an unless you can change to entirely firebrick, I'm thinking the problem won't go away.
The Following User Says Thank You to jlhaslip For This Useful Post:
jomama45 (10-31-2010)
Old 10-31-2010, 07:51 PM   #5
Rewards Points: 1,232
Anything in contact with direct flame or temps higher than 500 degrees needs to be lined with firebrick laid with refractory cement. It won't be long before the CMU begin to crack and spall.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 11-01-2010, 12:26 AM   #6
Rewards Points: 3,622
don't pay attn to the previous posters,,, what you need to do is build MUCH smaller fires then the block won't get hot,,, did you ever hear of fireplaces built from river rock exploding ? 1 of the things i remember from boy scout days amazing how much information was included in that little handbook & the merit badge pamphlets,,, guess those who play little league baseball, soccer, football, etc have as much ' real life ' information to get them thru life
of course listen to them - just had to get my $.03 into the thread,,, many changes have taken place in our culture at the rate is geometric
Old 11-01-2010, 07:58 AM   #7
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,504
Ayuh,... How about just leaving it be, 'n callin' it drainage....
It ain't like the fire is gonna drain out thru it...but the rainwater will...
Good product to fill cracks in concrete floor wvphysics Flooring 1 10-25-2010 11:49 AM
Repair on Concrete Drive Way Cracks jamiedolan Building & Construction 4 08-17-2010 11:40 AM
Foundation cracks drain tile fiveoh018 Plumbing 3 06-26-2010 02:55 PM
Advice needed for filling large basement Cracks dgbehrends Building & Construction 11 11-17-2009 04:23 AM
why wouldn't circuit breaker prevent fire? fauer Electrical 26 11-28-2008 08:38 PM
