Coved Floor Base Molding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-23-2015, 12:22 PM   #1
Rewards Points: 8
Coved floor base molding
Hey! The local health department requires that the walls/floor in a store room I am using be covered with some form of molding. The only requirement is that the molding is coved/curved (making it easier to clean)
Would anybody give me advice as to a cheap, easy to install, and durable product to accomplish this?
Thanks!
papashangu is offline   Reply With Quote
Old 10-23-2015, 01:18 PM   #2
Man of many hats
wrangler's Avatar
Rewards Points: 354
not sure what flooring stores may be near you, but this is one that's available from HD to give you an idea.
http://www.homedepot.com/p/ROPPE-Vin...P100/100581171
Man of many hats
wrangler is offline   Reply With Quote
Old 10-23-2015, 06:10 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 780
Papa,
The vinyl base wrangler mentioned should meet specs, but in some commercial rooms they may want 6" high base. I think rubber is better than vinyl, but both are acceptable.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 10-23-2015, 06:43 PM   #4
Rewards Points: 8
Thanks guys. There's a slight plot twist - about an inch above the floor, there is a pvc pipe anchored to the wall, running parallel to the ground for the length of the wall. Can the products you mentioned be cut to size?
Old 10-23-2015, 06:55 PM   #5
Rewards Points: 18,244
How about a picture?
NO baseboard will work with a pipe in the way?
What's in the pipe? Wires, air, water?
Old 10-23-2015, 06:58 PM   #6
Rewards Points: 8
Here is photo. Wires in pipe I believe.
Old 10-23-2015, 07:02 PM   #7
ZTMAN's Avatar
Rewards Points: 418
The vinyl cove that Wrangler identified would be the cheapest and easiest. Cuts with scissors. If you do get the vinyl cove do your self a favor and get the large glue tubes and the applicator attachment to apply the glue. Great time saver
ZTMAN is offline   Reply With Quote
Old 10-23-2015, 07:05 PM   #8
ZTMAN's Avatar
Rewards Points: 418
I would remove the conduit clips. Slide the cove behind the pipe, and then reattach
The Following User Says Thank You to ZTMAN For This Useful Post:
MaineLL (10-25-2015)
Old 10-23-2015, 07:07 PM   #9
Rewards Points: 8
Awesome! So just a spanner or screwdriver to remove them?
Old 10-23-2015, 08:04 PM   #10
ZTMAN's Avatar
Rewards Points: 418
I would be using an impact driver with the right sized socket to remove the clips
Old 10-23-2015, 08:19 PM   #11
Rewards Points: 8
Thanks for the advice! If I can get my hands on one of those, how would I reattach the pipe to the molding that is now behind it? Some kind of staple? I'm on a limited budget and can't afford any special equipment.
Old 10-24-2015, 09:43 AM   #12
Man of many hats
wrangler's Avatar
Rewards Points: 354
An inexpensive 6 in 1 screwdriver will do the trick. Part of the "6" is the 1/4" and 5/16" nut driver that holds the Phillips/standard screw driver bits. Back the screw out, slip base behind pipe and screw it back in the same spot.
Man of many hats
Old 10-24-2015, 10:16 AM   #13
Rewards Points: 8
Fantastic - thanks for all the help everybody. You guys rock.
Tags
molding coved wall floor
I need some opinions (and some answers) on molding oRIDDLERo Flooring 0 01-30-2015 02:17 PM
Trying to remove base molding h22lude Flooring 3 05-29-2013 01:59 PM
positioning molding joetab24 General DIY Discussions 0 08-11-2010 07:38 AM
Solidly Securing Picture Rail Molding? Lovegasoline Building & Construction 13 11-25-2009 03:13 PM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 11:52 AM
