Could A Guy Take A Building Like This - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-11-2009, 07:50 PM   #1
could a guy take a building like this
and put a 16' garage door under the over hang? maybe with a 10" lamb beam on top of the 6*6's?
the sliding door on the gable side wouldnt be there...this here building is 36*45....
ebstein is offline   Reply With Quote
Old 12-11-2009, 09:01 PM   #2
Old School
Willie T's Avatar
I would say probably "Yes". Because if you will notice the gable is balanced at the bottom where the white door slider hangs. Those overhang tails probably only carry the weight of the shed style overhang. You'd have to put an eyeball on the inside structure to be sure, but I think you'd be OK.
Unfortunately, you would likely have to retain that full wall where the three windows and personnel door are for the main roof support.
Willie T
Old 12-12-2009, 10:04 AM   #3
are the trusses notched into the 6x6? if they are, i dont know how you could put the beam ontop of the posts.
your in greenbay. so if stock lumber is still there(may be wis building center...or something like that) stock was sold..........the truss factory there can help you out with the size of the beam(doubt the 10" is going to be big enough. you may be able to notch the header into the posts.
hopefully the overhang is canted and the posts are really not needed. if this is the case, you should be able to do what ever you want to have a 16' Garage door.
i would still have the rep from the truss factory come over though.
good luck
kubie is offline   Reply With Quote
Advice on building a backyard studio/office? johnnyb10 Building & Construction 11 12-03-2011 11:43 PM
NEC uses building size?????? hhiibel Electrical 14 08-08-2008 12:19 PM
A steel building that doesn't look like a steel building? MMW Building & Construction 1 06-11-2007 04:24 PM
International building code and permits rforsha Building & Construction 4 08-28-2006 06:35 PM
