Cost To Alter A Small Shed Roof - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-19-2016, 05:58 PM   #16
Oso954's Avatar
Rewards Points: 332
I think you would also have to design a way to lower the upper part of the gable walls. They are fairly high on gambrel roofs. They would be liable to block a lot of the viewing area.
Even with more standard roof designs, there is a trade off in the height of the walls vs the line of sight for the telescope. So some sheds, particularly smaller ones, incorporate fold down walls. Some smaller sheds are also made as roll a way designs. The entire shed is rolled back away from the scope.
Oso954 is offline   Reply With Quote
Old 02-19-2016, 08:59 PM   #17
FNG
lugnutt73's Avatar
Rewards Points: 16
Good point, although since we're dreaming... I expect one could engineer the roof ends to pop out a bit and slide out and down to the ground. However, you'd need to have the door to the shed itself open to the inside (right or left) then there'd need to be another door, like a door to the hay loft but a walkthrough, and it would need to open to the outside of the building in the opposite right or left. Like screen doors and front doors...ish? Or am I just nutty?
lugnutt73 is offline   Reply With Quote
installing a metal roof on a shed will02 Roofing/Siding 15 04-08-2014 03:41 PM
Flat rubber roof. Can I add a small curb to two sides and slope run-off to the 3rd jkeuning Roofing/Siding 4 10-31-2011 12:04 PM
add shed roof to gable roof lucy1 Roofing/Siding 0 10-30-2011 09:31 PM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 01:35 AM
Tie a shed roof into existing 6/12 roof jj1122_2000 Building & Construction 1 02-18-2009 10:37 PM
