Cool Draft - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-28-2010, 11:31 PM   #1
Cool draft
My wife and I just purchased a home and I was uninstalling a fan in one of the second floor bedrooms. I felt a cool draft coming from the electrical unit. Is this a problem? Do we have insulation issues?
AMWski is offline   Reply With Quote
Old 12-28-2010, 11:48 PM   #2
A Little Of Everything
Rewards Points: 1,420
What do you mean by "electrical unit"? And are you talking about a ceiling fan being taken down?
Thanks.
DrHicks is offline   Reply With Quote
Old 12-28-2010, 11:50 PM   #3
Thanks.
The area where the fan attaches to the ceiling.
Old 12-29-2010, 12:15 AM   #4
Gotcha, thanks.
If you have cold air coming in through your electrical junction box you probably don't have very good insulation. Or at least it's not installed properly around the box.
Can you get up into your attic and look things over? Check the depth of your insulation?
Old 12-29-2010, 02:57 AM   #5
Rewards Points: 1,178
While you are at it, air seal the hell out of that box, and any other penetrations into the attic that you can get to. Don't rely solely on the insulation, esp if it is fiberglass batts. If you do have batts only, consider pumping some cellulose over top of it; that will improve the behavior of the 'glass a lot, plus add it's own help. j
Old 12-29-2010, 08:53 AM   #6
Rewards Points: 6,652
Draft coming through junction boxes, means that there is not enough installation above it. Seal the gap with low density foam (blue can), either from above in the attic, or below. Then get some more installation into the attic space. My guess is, that either min. amount was used up there, or it got pushed away, and never placed back. The links for Building Sciences, explains how to effectively seal the conditioned space, from the attic space. It should be at a difference of 10-15 degrees up in the attic, than what it is outside in the Winter time. If you are in the Snow Belt, or in the South, were it has been cold enough to put frost up on the roof in the morning, you can usually tell if the attic space is under-insulated, by snow quickly melting off, or the rafters showing through the frost on the roof.
Draft Inducer Blower Not Blowing- LED Blinking 3 Times rust101 HVAC 10 04-09-2013 09:44 PM
induced draft on same flue as natural draft Skippymartinez HVAC 1 12-08-2009 07:14 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 07:14 PM
Tempstar pilot not lighting after draft inducer replacement Kdavid HVAC 53 03-27-2009 03:10 PM
Water from cold water faucet goes from cool to hot to cool tima2381 Plumbing 6 05-22-2007 09:02 AM
