Constuction Adhesive - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-16-2009, 05:41 PM   #1
constuction adhesive
is it worth using construction adhesive on old framing im concerned about the bond
skeeter 152 is offline   Reply With Quote
Old 08-16-2009, 10:19 PM   #2
We pick these?
Hmmm... I wonder what you're bonding to it. My guess is that if you'd use an adhesive in the same situation but with new framing, you probably should do so with the old framing. I can attest to properly selected and applied adhesives bonding thoroughly and "permanently" to old framing, such as floor joists, sheathing, etc...
NailedIt is offline   Reply With Quote
Old 08-16-2009, 11:09 PM   #3
Rewards Points: 150
Nailed it! lol
Good advice run with it.
Good luck, be safe
Paragon is offline   Reply With Quote
Old 08-17-2009, 07:59 PM   #4
SNC
just clear out any loose debris before you glue
SNC is offline   Reply With Quote
Problems with Omni Grip tile adhesive Blue Flooring 24 05-15-2016 07:37 PM
Granite & Adhesive question cody21 Kitchen & Bath Remodeling 3 07-22-2009 05:11 PM
What type of adhesive should I use to glue down accoustical cork to a concrete floo Fixitgeorge Flooring 2 03-20-2009 07:54 AM
installing new bathtub, secure using construction adhesive or mortar? bsd Plumbing 24 03-05-2009 01:47 PM
Removing Vinyl Tile Adhesive from Linoleum The Raven Flooring 3 07-22-2008 08:38 PM
