Connect Glulam Beam End To End - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-01-2014, 11:29 PM   #1
Connect Glulam Beam End to End
I can't find a column cap that will connect two glulam beams end to end. Something like the Simpson CQQ. I read somewhere that the CQQ was not recommended to be used for two beams end to end.
Any suggestions will be appreciated, thank you.
DM007 is offline   Reply With Quote
Old 07-02-2014, 12:20 AM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 710
Don't know your application/specs, but you might have to have it designed/engineered and custom made/welded.
MTN REMODEL LLC is online now   Reply With Quote
Old 07-02-2014, 06:48 AM   #3
Rewards Points: 18,374
Checked on the web site of the company that made the Glulam?
Often times there's a ton of install directions and suggested fasteners.
More details on exactly what your trying to build may be helpful.
Old 07-02-2014, 07:02 AM   #4
kwikfishron's Avatar
Rewards Points: 166
Assuming you mean CCQ where do you see that you can't splice a beam on it?
kwikfishron is offline   Reply With Quote
Old 07-02-2014, 11:01 AM   #5
You're right is CCQ. I read it somewhere online can't remember. But do you know if you can connect two beams end to end on a CCQ? I want to try and use the same 6x6 post for a span on one side of 25' and the other side of 17'. The other ends of both beams will be resting on a bearing wall, more less it looks like a "T" with a bearing wall on each end, thanks.
Old 07-02-2014, 12:15 PM   #6
Rewards Points: 710
Well... It very well may fit..... but it is still an engineering issue...
Old 07-02-2014, 12:56 PM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 17,634
My second story would appear to be very similar to what you are describing....I have two PSL beams joined in the middle with a Simpson connector and 4x4 post. My drawings do not actually call out the Simpson connector in this area....but it did for the ends....EPC
What I used in the middle was not supper critical due to shear forces being handled by the roof sheathing and straps. Being the OCD person I am, I went pretty beefy....and I still have an MST-37 across the top holding the two beams together.
The Following User Says Thank You to ddawg16 For This Useful Post:
MTN REMODEL LLC (07-02-2014)
Old 07-02-2014, 01:29 PM   #8
Civil Engineer
Rewards Points: 5,246
The critical question in designing a method of connecting two glulam beams is the force that must be transmitted across the beams. The potential force across two beams joined end to end could include torsion (twisting), shear (both vertical and horizontal), and moment (bending). The required method of attachment depends entirely on which of these forces needs to be resisted, and the magnitude of the forces.
In standard framing, the joining techniques are usually spelled out in the building code, so you can be pretty certain that if you follow the code, you are going to achieve satisfactory results. In your case, there is not going to be a code section that details the connection, so you are going to need an engineer or architect to design the connection for you, based on the actual loads the connection needs to resist.
The Following 2 Users Say Thank You to Daniel Holzman For This Useful Post:
AndyGump (07-02-2014), MTN REMODEL LLC (07-02-2014)
Old 07-02-2014, 01:58 PM   #9
Rewards Points: 710
Thanks Dan...
(Ya mean you can't just toenail them together)
Best
Old 07-02-2014, 02:15 PM   #10
JOATMON
ddawg16's Avatar
Originally Posted by MTN REMODEL LLC View Post
Thanks Dan...
Best
I guess duct tape is out of the question as well?
Old 07-05-2014, 05:55 AM   #11
Rewards Points: 2,802
would baling wire work ?
irc
stadry is online now   Reply With Quote
Tags
clumns , glulam , post
Joists, Sill Plate, Foundation and broken main beam Bonebag Building & Construction 14 02-03-2013 08:40 PM
Drilling vertically through structural beam? dyi_sometimes Building & Construction 15 11-01-2012 01:43 PM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
Hanging loft from glulam beam, pics inside. wackerjr Building & Construction 20 01-05-2011 09:55 PM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 05:24 PM
