Concrete Over Rigid Insulation Garage Appartment - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-23-2010, 10:17 PM   #1
Concrete over rigid insulation garage appartment
I want to level the floor with concrete. Size is 13' wide and 20' long. At the front ( thin ) end i can come up only 2 inches to ff. The deep end is 4" thick. Code requires 2" rigid insulation up the stem wall to green plate all the way around the perimeter and 2 feet laying horizontal into the living area ( this is only along the 13' X 4" deep end.)
Goals (wants)
1. Elec. Wire radiant floor heat or ceiling radiant panel heat, or?
2. Acid Stained concrete with smooth finish ( and poss. A few Strategic placed ceiling radiant panels)
Is this a gypcrete project?
Can gypcrete be acid stained?
How thin can concrete be and not crack all over.
What about deep end concrete and shallow end gypcrete product?
I plan to use an adherent between existing and new floor
Twinguy2 is offline   Reply With Quote
Old 11-25-2010, 04:48 PM   #2
Goals (wants)
I am open to other suggestions for heating
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 03:56 PM
Damp Concrete Garage Floor Tom S. Building & Construction 15 03-27-2010 08:23 AM
Building garage with elevated concrete floor dmj245 Building & Construction 13 05-31-2006 04:13 AM
Garage Concrete Slab...HELP? Aqua-Man Building & Construction 2 06-17-2005 01:11 PM
