Concrete Kneewall Finish? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-04-2012, 12:45 PM   #1
Rewards Points: 252
Concrete kneewall finish?
I'm putting an addition onto my house and the foundation at the rear of the addition steps up 1 foot because the house is built into a slight hill. The walls are 2x6 and the foundation is 8" poured concrete, so this leaves a ledge on the inside. The problem is that I have stairs running parallel with the step in the foundation and the more I move them away the more room I lose elsewhere.
What are my options for finishing the concrete and keeping the stairs as close to the 2x6 studs as possible? Can I glue drywall to the concrete or do I need to fur it? Should I rest the stair stringer on the concrete and narrow the last one or two treads? Any suggestions are appreciated!
shazapple is offline   Reply With Quote
Old 07-04-2012, 06:41 PM   #2
Rewards Points: 1,178
I guess it somewhat depends on how wide your stairs are. If 2" won't make stink for a difference in the width of the stairs, then narrow up the last few steps and set the stair stringer on the concrete if necessary. That is not ideal, but life has compromises. Use EPDM gaskets or treated lumber against the concrete. Why not just paint the concrete for that little bit? Too ugly?
Basement Finish - Soffit Against Poured Concrete InDashMP3 Remodeling 16 04-10-2012 10:18 AM
What's wrong with this concrete finish? Joepublic Building & Construction 8 09-04-2011 08:31 AM
Bathroom Remo: Is this Plaster over Concrete Block? Mounting Backerboard over top? itcanadian Remodeling 10 03-21-2011 01:06 PM
Ideas on a thin or faux concrete finish to a table? groovmuffn Carpentry 3 03-20-2011 01:22 AM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 05:53 PM
