Concrete Counter Tops - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-30-2009, 10:53 AM   #1
Question
Concrete counter tops
Can someone give me the mixture for concrete counter tops???
Sawsall is offline   Reply With Quote
Old 07-30-2009, 11:03 AM   #2
RippySkippy's Avatar
The search bar is your friend.
Here's a thread that discusses their experiences...http://www.diychatroom.com/f49/my-ki...ntertop-19987/ Read the whole thread...good stuff.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 07-30-2009, 11:07 AM   #3
Registered User
Termite's Avatar
There's a lot to it and none of it involves normal sackrete and portland, which shrinks too much when hydrating. There are some great books available on the subject. The mix is often available at specialty retailers but rarely at box stores.
Old 07-30-2009, 11:29 AM   #4
Thanks for the help and advice.
Old 07-30-2009, 11:50 AM   #5
long island, NY
also be aware that concrete counters, while gorgeous, are really porous.... even when sealed properly. If you're a sloppy chef, you might want to instead select a less porous option... (formica, stainless, granite)
diy'er on LI is offline   Reply With Quote
Old 07-30-2009, 10:49 PM   #6
Rewards Points: 3,622
all those guys're right & we make 'em if i had to choose a bagg'd mix, i'd pick rhodes over cheng,,, buddy's a conc guy & cheng's approach is from design,,, gimme the pro every time
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
Corian or Granite counter tops Jms92 General DIY Discussions 21 04-17-2010 06:18 PM
concrete counter tops rwongrey Remodeling 10 07-13-2009 01:25 PM
laminating counter tops ponch37300 Remodeling 3 05-13-2009 10:13 PM
