Conc Pavers Over Conc Slab ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-08-2010, 01:51 PM   #1
conc pavers over conc slab ?
My friend tells me we can lay down 4"x8"x2" concrete pavers right over the existing concrete patio slab since the added 2 inch height is not a problem. Is he correct, and if so, do we use mortar mix and a notched trowel to lay them in ?
I know the thin pavers are best for this, but already have the thicker ones.
Thanks for the help.
hughnohoo is offline   Reply With Quote
Old 11-08-2010, 10:00 PM   #2
Having a concrete base for paving stones is ideal. No chance for future settling.
There could be a problem if the slab is cut into sections. If so, one slab may settle more than the other.
If the slab is cut, I would suggest cutting the stone to match at the same place.
You would need to have the perimeter anchored to keep it all from spreading.
Pouring Patio Slab and Post Footings Question average_male Building & Construction 22 04-04-2016 12:13 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
engineer wood floor @ uneven Slab on grade gtimk4 Flooring 0 03-21-2010 06:29 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 12:23 PM
conc slab inside/under a enclosed metal carport blthomas Building & Construction 3 02-01-2008 09:18 AM
