Composite Decking Overhang - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree10Likes
  • 2 Post By kwikfishron
  • 1 Post By Nealtw
  • 2 Post By jayman9782
  • 2 Post By Clutchcargo
  • 2 Post By Californiadecks
  • 1 Post By Californiadecks
Old 03-09-2020, 03:55 PM   #1
Rewards Points: 14
From what I have read, I made a rookie mistake and started installing my composite decking from the inside edge out when I should have started the other way.
That said, I now have 3" remaining on the outside edge and my boards are 5 1/2" wide. Does anyone have any suggestions on completing the project? Unfortunately, it's not as easy as adding another rim joist due to my steps. I have included some pictures.
Thanks in advance.
Composite Decking Overhang-img_5165.jpg   Composite Decking Overhang-img_5167.jpg
jayman9782 is offline   Reply With Quote
Old 03-09-2020, 04:03 PM   #2
JUSTA MEMBER
Rewards Points: 3,992
Re: Composite Decking Overhang
Rip cut the plank. then place a grove cut along the side, for a tongue to fit.
Remove 1/2 the installed ones, put the narrower one in the middle, replace the other planks and call the narrow one an ACCENT piece.
Or add a second rim joist, and maybe a third.
ED
de-nagorg is offline   Reply With Quote
Old 03-09-2020, 04:03 PM   #3
Usually Confused
lenaitch's Avatar
Rewards Points: 2,102
Your outer board should not have a groove in it (like the board on the riser in you pic). You only options at this point are to rip it to the width you want and paint the edge with the touch-up paint they sell. If you do have (or get) a non-grooved board, you can still rip it, then flip it around so the cut edge is facing in. You can cut slots for the mounting clips using a bit and router.
_________________________________________
Bydand
lenaitch is offline   Reply With Quote
Old 03-09-2020, 04:07 PM   #4
retired framer
Rewards Points: 15,762
You could cut it and do the round over with a router.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Nealtw is offline   Reply With Quote
Old 03-09-2020, 04:15 PM   #5
kwikfishron's Avatar
Rewards Points: 512
This is a good example of why I always run my joist wild and just start decking.
I start decking with a full board from the house out until I'm a couple of courses from the end. At that point I'll snap a line, cut the joist and install the rim so I'll end up with a full width board on both ends.
You still have time to do that, you may have to remove one course though to give you enough room to cut the joist back.
Btw, you can get those deck boards with the groove on only one side. You use those for the last/finish course.
kwikfishron is offline   Reply With Quote
Old 03-09-2020, 04:25 PM   #6
retired framer
That's cheating, I like it.
de-nagorg likes this.
figure 7-14
Old 03-09-2020, 05:47 PM   #7
Rewards Points: 14
Thanks everyone for the suggestions. I had considered ripping the board and routing then painting it after, I just hoped there was a better way. Guess I'll go that route.
de-nagorg and Nealtw like this.
Old 03-10-2020, 07:55 AM   #8
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,998
Similarly, I start at the far side and work toward the house so that the ripped board is against the house.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 03-10-2020, 11:58 AM   #9
Rewards Points: 512
The way I was describing there are no ripped boards.
Old 03-10-2020, 12:13 PM   #10
General contractor/carpen
Californiadecks's Avatar
Rewards Points: 1,002
You can purchase a square edge board that wraps the cap all the way around. Route the cut edge and buy some color matched paint. Composite takes paint extremely well. You can also use a biscuit cutter to groove the cut edge. Or just use color matched screws (fastenmaster) on every other joist. They are not a bad look, imo.
Or put the cut edge out then you can use the grooved board.
Mike.
_______________
lenaitch and de-nagorg like this.
Californiadecks is offline   Reply With Quote
Old 03-10-2020, 12:14 PM   #11
We paint ends all the time without issue.
Mike.
_______________
Old 03-11-2020, 06:06 PM   #12
I have gas!
Sorry, should have clarified...
I meant...
similarly, exposed edge is not cut.
Tags
composite deck , overhang
