Cold Climate Folks ..... - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree3Likes
Old 10-19-2017, 08:18 PM   #16
jlhaslip's Avatar
Rewards Points: 708
Re: Cold climate folks .....
Pouring the footings/walls and leaving them exposed is not a good thing.
If frost gets to the footing level without heating the soil around them, it will heave, so if the concrete gets poured, make certain to take precautions against frost.
On more than one job, I have seen an electric water tank installed to circulate hot water through a hose embedded in the footing. Was cheaper than propane heat for the 4 months it was required.
i have also seen the results of not heating the footings ubder the same conditions and it was not pretty. Needed to wait until spring thaw to see the footings settle back down before continuing on the subfloor. Centre post pads were lifted 4 inches. True story.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 10-19-2017, 08:23 PM   #17
jlhaslip's Avatar
Rewards Points: 708
Originally Posted by lenaitch View Post
In the Fraser Valley, "cold weather" is, what, almost freezing?
To come to Neal's defense, I have driven the highway from Hope to Vancouver during a blizzard and it is down right scary. Mostly because the cars and drivers are not familiar with real winter driving and continued to drive waaaaaaaaay too fast for the conditions without proper tires.
Old 10-19-2017, 08:37 PM   #18
retired framer
Rewards Points: 1,544
metric 5* sounds cold.
Nealtw is offline   Reply With Quote
Old 10-19-2017, 08:46 PM   #19
Usually Confused
lenaitch's Avatar
Rewards Points: 246
You just described most of Southern Ontario - pretty much any time of the year!
That's when I'm thinking of putting my m/c away!! (actually I pretty much draw the line at 10*C but have ridden in 3*C and snow - when you're 500k away from home, whatrya gonna do)
lenaitch is offline   Reply With Quote
Old 10-19-2017, 08:52 PM   #20
retired framer
We have one section that gets closed down when the snow blows it is just a white out. You don't notice it till you are in it at 100 kph. If you keep going you hit some one, if you slow down some hits you. Never ends well.
Old 10-19-2017, 09:09 PM   #21
jlhaslip's Avatar
Rewards Points: 708
In January, there was an inch of inch on the roadway, grass showing at the side of the road and a car on its roof. About 6 years ago. The truck I had was equipped with winter (studded) tires and had no problem at 80 kliks but the idiots were passing me sideways. Crazy.
Between Chiliwack and Abbotsford I counted 37 vehicles abandoned..
Old 10-19-2017, 09:33 PM   #22
retired framer
Yup, the limit is 110 so 120 is the normal in all kinds of weather.
Cold Air Supply Design Beepster HVAC 4 10-28-2012 07:06 PM
Trickle of Cold Water Pioneer Bathtub Faucet egawrons Plumbing 0 10-25-2012 12:24 PM
Warm Water out of Cold Water Outlet mb0709 Plumbing 9 08-26-2012 01:59 PM
Cold Climate Duct Work rhysup HVAC 10 04-12-2012 07:55 AM
Cold air return questions ekulrenlig HVAC 19 10-09-2009 02:44 PM
