Code Reuirements For Ceiling Joists - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-02-2009, 11:44 AM   #1
Rewards Points: 562
code reuirements for ceiling joists
I tore down an existing old ceiling because it was BAD. span is 9'6" with joists on 16" centers. Will 2X4's hold 5/8 drywall,,,or do I require 6" lumber there?
4just1don is offline   Reply With Quote
Old 06-02-2009, 12:12 PM   #2
Rewards Points: 5,348
What's over this area? Even 2x6 is small with a floor or storage above this space. If nothing will ever be put up there, a 2x6 would be my choice.
Ron
Old 06-02-2009, 12:18 PM   #3
Does this mean you're using the 2x4's as furring strips?
walkman is offline   Reply With Quote
Old 06-02-2009, 12:37 PM   #4
I have gas!
Clutchcargo's Avatar
Rewards Points: 2,046
2x6 minimum according to AWC
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Sister or Replace Floor Joists brando1118 Carpentry 25 10-26-2008 08:43 PM
Buidling code for deck and nailing schedule Jozee Building & Construction 7 10-01-2008 12:46 PM
help with 2nd floor joists g heil Building & Construction 5 09-12-2008 06:41 PM
Best subfloor and material thickness nugentcn Flooring 7 09-07-2008 12:48 PM
Code - Framing Under 2nd Floor Bathtub austinbirdman Building & Construction 2 03-04-2007 02:14 PM
