Cleaning Loctite PL Window Door & Siding Polyurethane Sealant? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-19-2017, 10:22 PM   #1
Rewards Points: 2,446
Well, I somehow got a smear of the Loctite PL Window Door & Siding Polyurethane Sealant on my new pair of jeans.
Is there anything I can do I dissolve/clean it?
miamicuse is offline   Reply With Quote
Old 10-19-2017, 10:53 PM   #2
Rewards Points: 1,830
Re: Cleaning Loctite PL Window Door & Siding Polyurethane Sealant?
Stretch that spot over something like a cutting board, and use a not too sharp knife to scrape as much of it off as possible. Use a scraping motion, not a cutting motion. If some still remains because it soaked in, use something like Goo-gone or lacquer thinner or acetone, and a lot of Q-tips to dab it off.
ChuckF. is offline   Reply With Quote
Changing Window Size TinaV Remodeling 3 11-06-2012 01:30 PM
new construction window over old layer of siding goodr511 Building & Construction 19 07-02-2012 10:53 AM
Window flashing over T1-11 siding ajhutt Building & Construction 2 05-01-2012 12:58 AM
Adding a window - cutting through Aluminum Siding -how to repair siding to look good? DyerWolf Building & Construction 6 12-22-2008 05:02 PM
