Cleaning Exterior Masonry Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-10-2010, 02:20 PM   #1
cleaning exterior masonry walls
I bought a 1920s home last month. The exterior is an aggregate cement. My first mission was to clean what looked like a buildup of dirt under the overhangs and part way down the walls (around the entire home).
Tried spraying with a power nossle, then "Krud Kutter". Even took a hose and broom to scrub the dark areas. No luck.
Any ideas?
TomMac is offline   Reply With Quote
Old 10-11-2010, 02:40 PM   #2
Rewards Points: 3,548
3 c clorox : 1 c dawn dishwashing detergent in 1/2 gal water sucked up by the intake hose on your rented pressure washer - 2,500psi minimum,,, we use turbo nozzles on 4,000psi machines
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
Cleaning candle wax off walls spaceman spif Painting 4 09-23-2010 09:21 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 08:17 AM
Cleaning Walls after wallpaper removal saggdevil Painting 28 06-16-2009 04:32 AM
Moisture on walls chrisr Building & Construction 1 01-20-2008 09:37 AM
