Clay Flue To Metalbestos Transition - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-29-2010, 05:19 PM   #1
Location: I own a home in CT, but I'm a travelling snowbird come winter.
Question
Clay flue to metalbestos transition
I'm raising my roof to accomodate a loft. The exterior wall runs up along my fireplace chimney which will have to be extended. I was hoping to do the extension with metalbestos pipe. My problem is trying to find a transition piece that will take me from the square clay flue to the 6" round metalbestos. Any ideas?
Stan
sjptak is offline   Reply With Quote
Old 07-31-2010, 03:46 PM   #2
Registered User
Rewards Points: 526
Search on-line or at a local sheet-metal shop.
Be safe, Gary
clay cap around foundation? patrickosu Building & Construction 5 08-21-2010 04:55 AM
Tiling entryway - proper transition for this scenario? Scott99999 Flooring 5 12-22-2009 12:12 AM
Engineered Hardwood: Inlaid transition? SteveSmith98 Flooring 6 03-24-2009 11:21 AM
hardwood to tile transition navychief39 Flooring 8 03-04-2009 06:32 AM
1.75" room / floor transition MrLinux Flooring 1 03-11-2008 02:19 PM
