Cladding Ideas For Closed In Garage Entrance - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Nealtw
Old 11-11-2019, 11:40 AM   #1
Rewards Points: 400
Cladding ideas for closed in garage entrance
I'm looking for some economical ideas to make this closed in garage door opening presentable. It doesn't have to be the cheapest of the cheap.
The opening
Currently the space is drywall and 2x6 framing. Originally this led into a garage, so I was not planning on having it exposed to the elements. I've since detached the garage from the house.
The foundation is a type of cut face block. From my googling, it seems at the time this house was built, the foundation blocks were probably made on site. I've found two companies that are able to match (or closely match) the current block, but the cost is more than I want to spend.
Whatever I go with, I would like it to somewhat match. Some sort of masonry? Stucco? I would like to avoid siding, but maybe there is something that I'm overlooking.
Fisher1871 is online now   Reply With Quote
Old 11-11-2019, 11:54 AM   #2
retired framer
Rewards Points: 4,926
Re: Cladding ideas for closed in garage entrance
Can you lift the door a few inches so that area can handle an inch of water.
Do not use flat bottom gables with scissor trusses.
Old 11-11-2019, 12:11 PM   #3
Hammered Thumb
Rewards Points: 792
IMO "cheap" and "match" are contradictory in this instance. No matter what cladding, it will always looks like a garage door has been filled in. Only a wall of sliders/windows would it seem originally intended. Will you have a full deck above hiding some of this visually?
+1 on the water.
3onthetree is offline   Reply With Quote
Old 11-11-2019, 12:56 PM   #4
Rewards Points: 400
+1 on the water.
Yes, there will be a deck above and some lattice or something on the sides. The stairs leading from the porch to the ground will be off to the right.
Old 11-11-2019, 12:59 PM   #5
Rewards Points: 400
I can't remember off hand - I'll have to look. I think that the top of the door frame is directly against the steel header of the original garage door.
Old 11-11-2019, 01:08 PM   #6
retired framer
Then I would shorten the door and the jam so you could put a door pan in and a peel and stick and a flashing right across the wall behind the siding
Old 11-11-2019, 02:27 PM   #7
retired framer
@Fisher1871
I think I would go extra for water proofing and just built out another 1 1/2" so it would be like this.
Cladding ideas for closed in garage entrance-fis-2.png   Cladding ideas for closed in garage entrance-fis-3.png   Cladding ideas for closed in garage entrance-fis-4.png
Fisher1871 likes this.
Old 11-11-2019, 02:37 PM   #8
Rewards Points: 400
@Fisher1871
That's an interesting idea. The wall on the left protruding out from the foundation will be removed.
Old 11-11-2019, 03:08 PM   #9
retired framer
That would still work and hide what ever ugly is left when it is removed.
I did this to should how you could trim it.
What is the plan for the upstairs deck now?
Old 11-11-2019, 03:26 PM   #10
Rewards Points: 400
Build a deck and tie it into the 6x6 posts. 5 1/4 deck boards. Maybe a composite if I can get a good deal.
Old 11-11-2019, 03:49 PM   #11
retired framer
Have a look at what Cal deck does for water catching around post #210
https://www.diychatroom.com/f49/day-...1/#post5974379
Old 11-11-2019, 04:12 PM   #12
Hammered Thumb
Rewards Points: 792
You can reuse the blocks on the left wall you're going to remove, they look the same. Did you save any of the siding from the garage demo? That'd be a perfect match to above, and would be super cheap and make sense visually.
Old 11-11-2019, 04:18 PM   #13
Rewards Points: 400
Unfortunately the cut face block from that wall on the left are in really bad shape. Not properly protected from weather I guess. I can dang near remove them with just my hands.
The siding that was on the garage was a gray vinyl that was a close match to the siding on the house. The siding on the house is aluminum and was installed in the early 70s. Pretty heavy gauge. The metal siding has sort of a unique siding lap measurement as well.
