Cinder Block Mini? Cracking - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-02-2016, 07:33 PM   #1
Rewards Points: 4
Cinder block mini? Cracking
Hi all. I was walking around my house today and noticed this on the outer wall of my garage. It's just passed where the Water heater (which is in the garage) vents out. This looks scary to me. Looks like some serious cracking issues. Is this a foundation issue? Or an issue with the cinder blocks that surround the slab? There is nothing obvious going on inside the garage, or near, around, or anywhere inside the house really. All doors, windows and the like open fine. No cracking drywall or anything. It appears to be right at the point where the garage slab meets up with the house slab...or are these connected? There is approx a 3" difference between the garage floor and the house...which is why I'm guessing there are two different slabs. The Cinder blocks go around the main house slab correct? What is with the baby blocks? Seems like a crack waiting to happen. I'm really nervous I have some major foundation issues, but other than the cracks here, there's nothing to note. Any help would be greatly appreciated thanks.
Cinder block mini?  Cracking-20160802_174302.jpg   Cinder block mini?  Cracking-20160802_174248.jpg   Cinder block mini?  Cracking-20160802_174242.jpg
texhater is offline   Reply With Quote
Old 08-02-2016, 07:52 PM   #2
Rewards Points: 3,642
Re: Cinder block mini? Cracking
Is there any records available that the garage was added a few years after the house was built?
I really don't see a serious problem there that re-pointing wouldn't take care of.
Old 08-02-2016, 08:01 PM   #3
Rewards Points: 4
No, pretty sure the garage was poured when house was being built...that's how all the houses around here are. House is about 20 years old...if that matters. What is "re-pointing"?
Old 08-02-2016, 08:05 PM   #4
Rewards Points: 8,128
One good thing about foundations that settle, they do so slowly. As SS says, repoint it and see what another season or two does.
Bud
Bud9051 is offline   Reply With Quote
Attaching patio cover to the top of cinder block wall robertwallace Building & Construction 7 07-10-2012 11:22 PM
Removing White Powdery Substance From Cinder Block Lawrence Coppar Concrete, Stone & Masonry 5 04-12-2012 03:28 PM
Wire through cinder block drjay9051 Electrical 1 12-07-2010 01:42 PM
# of rebar in cinder block wall johnlvs2run Building & Construction 3 08-08-2010 11:48 AM
Tying in a 2"x4" walled-booth with a cinder block wall johnofthemount Building & Construction 3 12-19-2009 03:51 PM
