Cinder Block - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-30-2010, 01:43 PM   #1
cinder block
My daughter moved into dorm room this week end. Need suggestions in how to get curtain rod holder to stick on cinder block. We used those new command stickers that have the pull tab so as not to ruin wall, but they fall.
Debbied2u is offline   Reply With Quote
Old 08-30-2010, 02:41 PM   #2
Old School
Willie T's Avatar
Can you use the type of curtain rod that the ends screw out and it fits by force of friction? I think they also have them with springs in the ends for hanging light weight curtains.
Willie T
Wire through cinder block Red Squirrel Electrical 9 07-04-2010 04:45 PM
Insulate Top of Cinder block wall HooKooDooKu Building & Construction 0 01-20-2010 10:58 PM
Fire blocking a wood stud wall built against cinder block. BasementVirgin Building & Construction 1 10-05-2009 11:02 PM
Cutting cinder block for a large door opening joeyb Building & Construction 2 02-10-2008 12:00 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
