Chimney Cap Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-30-2015, 07:41 AM   #1
Rewards Points: 121
I am looking for an economical way to cap a chimney for a fireplace I do not use.
Well, actually we switched from the old wood burning unit to a new gas fireplace and have vented it out the back. Now I want to cap the old fireplace. Right now it has what looks like sheet metal with a hole for the old metal pipe. The chimney box itself is wood framed with cedar siding, about 42" by 66". I was thinking of getting sheet metal and having it bent a couple of inches around the edges for attachment. Does not need to be pretty, not visible from the street or the rear, just needs to keep the weather out.
If you all think that might work then what metal and thickness would be best? Other opinions on options appreciated.
JoeLena is offline   Reply With Quote
Old 06-30-2015, 07:46 AM   #2
Rewards Points: 474
I believe you have your answer, simple but yet effective.
BrowneBearLLC is offline   Reply With Quote
Old 06-30-2015, 08:03 AM   #3
Rewards Points: 121
Just confused about which metal and thickness I suppose.
Old 06-30-2015, 11:46 AM   #4
Rewards Points: 474
I see sorry, I just do them with standard aluminum that one would use on a house.Just do not use steel due to rusting where you will get stains running down the side
Old 06-30-2015, 04:01 PM   #5
Rewards Points: 121
Okay, thanks! Sounds like a good plan.
Old 06-30-2015, 04:55 PM   #6
Rewards Points: 80
I've used steel before, but only where i didn't care about rust stains. Aluminum is great. Any gauge works really. Nothing specific needed.
Cheers!
supers05 is offline   Reply With Quote
Old 06-30-2015, 05:11 PM   #7
kwikfishron's Avatar
Rewards Points: 60
Go to a local HVAC company with a shop. They fabricate this type of thing all the time. They'll be able to help you with material choice.
If you're going to supply the measurements then be sure that chimney is square as many of them are not. If yours isn't square then make a plywood or cardboard template and take that to them. Be sure to oversize it a bit so you know it will fit.
kwikfishron is online now   Reply With Quote
Old 06-30-2015, 06:00 PM   #8
Low Slope Roofing
Rewards Points: 114
For a few bucks more you can get prefinished steel. No rust to worry about, or galvanized will work also. I'd be careful with what gauge you use, some were built rather cheap and may not have a plywood base.
1985gt is offline   Reply With Quote
Old 06-30-2015, 09:37 PM   #9
Rewards Points: 1,826
Roofing companies do cap replacements too. In your unusual case you want the 'no hole' option. They will put a kickout on the flange and an 'X' on the top to keep it domed so water won't collect up there.
ChuckF. is offline   Reply With Quote
Any chimney sweeps here? Question: noquacks General DIY Discussions 4 12-08-2010 11:46 PM
Concrete block Chimney problems scoggy Building & Construction 0 03-09-2010 08:00 PM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 12:23 PM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 04:12 PM
