Center Beam Support W / Lallys - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-23-2010, 06:37 PM   #1
Center Beam support w / Lallys
I have 60's 40' ranch with a a one car basement garage. I need to store a classic car on the other side of 4 Lally columns. The center beam is made up of only 3, 2x8's. I need an 18' span in just the center basement that is clear of columns to maneuver this old car into this space. However there are load bearing walls that run the entire length of the living space above. I hearing "add plywood and you can remove the columns" something I don't want to do! I'm also told to add a steel, "U" channel and return the 2 columns back to 18" opening on each end. (Sounds much safer to me!) I don't have the budget for an I beam support replacement but, I must keep safty and integrity in mind. Any helpful suggestions would be greatly appreciated. Thank You, Don
Donsdmp is offline   Reply With Quote
Old 05-23-2010, 07:48 PM   #2
Have an engineer/architect/local lumber store size an LVL to carry the load
Plywood won't do it
Support I beam needed ThisOldH0use Building & Construction 28 05-16-2012 09:10 AM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 01:07 PM
Ceiling joists support beam ptcamaro Building & Construction 3 06-17-2009 10:14 AM
Ductwork Around Center Beam Build HVAC 6 06-16-2009 10:56 AM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 04:24 PM
