Cement Board Into Furring Strips ?? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-29-2017, 03:36 PM   #1
Rewards Points: 124
Cement Board into Furring Strips ??
I need some help/advice on a project I'm working on - If this should be posted in a different section, please let me know.
I'm refinishing a 1/2 bath in my basement. The bathroom has 3/4" furring strips along the exterior wall and I wanted to attach hardieback or some kind of cement board along the bottom, about 48" high to support tile. After looking at the products available, I'm not sure how I can make this happen. The cement boards are a little less than a 1/2" and the screws 1.25" ... Is there a 1" screw ? Is there any cement board product I can attach to 3/4" furring strips. I would appreciate any thoughts or suggestions - I cannot frame out the exterior wall, it's just not possible given the space the heating pipes that run above.
Thank you
JohnyFever is offline   Reply With Quote
Old 05-29-2017, 05:21 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 8,606
Re: Cement Board into Furring Strips ??
Snip the screw or pre-drill the holes and go into the wall slightly.
Old 05-29-2017, 06:44 PM   #3
Rewards Points: 898
Thank you
http://www.homedepot.com/p/Grip-Rite...DWS1/100162981
And
http://www.homedepot.com/p/Loctite-P...0594/202020474
BIG Johnson is offline   Reply With Quote
Old 05-29-2017, 08:26 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,578
if its a half bath why are you using concrete board ? you dont need concrete board to tile to if its not a wetting area.. meaning not a shower . regular drywall or greenboard is perfectly acceptible
woodworkbykirk is offline   Reply With Quote
Old 05-29-2017, 08:30 PM   #5
Totally missed that.
Messy peeling?
Old 05-29-2017, 10:53 PM   #6
Rewards Points: 124
Thanks for the replies everyone - appreciate it.
It's a basement bathroom - I know at some point there will be water down there. The basement had drywall before I gutted it and the backside was completely moldy - I definitely want concrete board as my base (if possible).
I've used the Locktite adhesives before and I know they hold strong, but not sure I would trust them for this kind of application.
I had thought about shortening the screws myself since it's only one wall that is an issue and it's pretty small - Do you think there is any issue with doing that ? That was my last resort if I could not find a better alternative.
Thanks a lot
Tags
cement board , durock , furring strips , hardiebacker
Wiring ceiling and furring strips benleef Electrical 12 01-12-2015 07:58 PM
egads, do I need to rip out my cement board and start again? soberjulie Flooring 38 06-28-2013 11:27 AM
Replacing Rim Board behind old Deck Ledger osubuckeye88 Building & Construction 11 10-26-2012 08:34 PM
Cement board meets drywall? CowboyAndy Drywall & Plaster 8 12-25-2010 09:29 PM
Cement Board to Green Board Question ryan5068 Tiling, ceramics, marble 10 05-12-2010 07:29 PM
