Cement Board - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-04-2013, 03:08 PM   #1
cement board
I have a BIS panorama, airtight, wood burning fireplace. I studded the surround with metal studs and covered the area with Durock New Gen cement board right up to edges of the stove. I now read that the NFPA do not consider this product a non-combustible! I called USG support and was told that they do not recommend any board material as a fireplace surround? They also said that product was fire-rated for 125F I'M CONFUSED! I thought was the whole reason to use cement board and not drywall. Even plywood will not take fire at 125F
Does anyone have any ideas?
buz
buz938 is offline   Reply With Quote
Old 12-04-2013, 03:23 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 10,042
I would suspect this issue is out gassing...in other words, what kind of fumes are giving off when it gets hot.
Why not look at the MSDS for the product?
ddawg16 is online now   Reply With Quote
The Following User Says Thank You to ddawg16 For This Useful Post:
buz938 (12-04-2013)
Plunge cut cement board - or not? miamicuse General DIY Discussions 5 11-13-2013 09:58 PM
Type nails? - wooden trim into cement board Easypick Carpentry 5 07-21-2013 04:16 PM
yet another cement board question echobravo Kitchen & Bath Remodeling 4 01-23-2012 05:39 PM
Installing Stone Veneer to cement board on a wall Augy Building & Construction 2 01-20-2012 07:17 AM
Cement Board to Green Board Question ryan5068 Tiling, ceramics, marble 10 05-12-2010 07:29 PM
