Cement Additive - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-16-2011, 09:54 AM   #1
cement additive
A brick mason told me there is an additive that can be added to your cement mix that makes it hold better when you are working over head with brick veneer - any idea what it's called
IVANHO is offline   Reply With Quote
Old 02-16-2011, 10:27 AM   #2
Concrete & Masonry
Rewards Points: 494
Bonding agent, just make sure you get one that specifically states that it's an admixture, meaning it can be added to the mortar rather than the two substrates (the brick & ceiling in your case) directly.
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
IVANHO (02-16-2011)
installing Slate title to outdoor cement Matky Flooring 53 04-05-2010 07:08 PM
general question on portland cement rtoni Building & Construction 2 07-11-2009 08:32 AM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 02:25 PM
cement falling into basement from cement porch above. Betsy G Building & Construction 3 10-21-2007 12:53 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
