Ceiling Strapping - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-02-2019, 08:01 PM   #1
Rewards Points: 54
Ceiling Strapping
Im putting 1x3 strapping on my basement ceiling for dry wall. If 2 lumbers joins in the middle of the joist cavity, how would i join them? Should i nail blocks? Or should i just leave them without fastening them together?
deepsweech is offline   Reply With Quote
Old 06-02-2019, 08:49 PM   #2
Super Moderator
Gymschu's Avatar
Rewards Points: 266
Re: Ceiling Strapping
You shouldn't have strapping that stops in the middle of the joist cavity. You would want to cut them so they share space on a joist. In other words, they would "butt" together on the same joist. If that's not possible, you would need to put up some 2 x 4 nailers between the joists so the strapping has something solid on which to be nailed. If you just leave them floating, then when you install your ceiling drywall, you will have a weak spot that could sag, etc.
"In the heat of battle, my father wove a tapestry of obscenity........."
Old 06-02-2019, 09:45 PM   #3
retired framer
Rewards Points: 4,856
Joist put a 2x4 above them and screw into it.
Do not use flat bottom gables with scissor trusses.
Nealtw is offline   Reply With Quote
Old 06-02-2019, 10:16 PM   #4
Rewards Points: 284
The Gypsum Construction Handbook has a section on adhesive application it states that the adhesive should meet ASTM C557 this section covers wall & ceiling adhesive methods. You need to follow the guide lines in this section.
This post is under in wrong thread.
ClarenceBauer is online now   Reply With Quote
