Caulking - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-19-2018, 06:44 AM   #1
Klutz Extrodinaire
Rewards Points: 158
Caulking
So I was always taught that caulk doesn't stick to caulk and if you had a gap, rip it all out and start over.
I know that's true of silicone, but I was recently introduced to something I'd never seen before: butyl caulk. Is the above still true? If I want to touch up somewhere that butyl was installed, can I just squirt a little extra butyl on there, or do I have to dig out all the butyl that's there first?
TinyFargo is offline   Reply With Quote
Old 07-19-2018, 07:55 AM   #2
retired painter
Rewards Points: 1,784
Re: Caulking
A lot depends on what/how you are adding the additional caulk. I've recaulked voids numerous times without any issues. Where you can run into trouble is trying to apply a thin coat of caulking over the existing caulk.
Butyl caulk isn't used much today - what do you intend to caulk with it?
mark sr is online now   Reply With Quote
The Following User Says Thank You to mark sr For This Useful Post:
TinyFargo (07-19-2018)
Old 07-19-2018, 06:35 PM   #3
Klutz Extrodinaire
Rewards Points: 158
Re: Caulking
Butyl caulk was used to seal between a set of steel doors and the concrete foundation. There is a very small void in what was done. Access to remove the material is very difficult without making a much larger mess... which is why I want to try to supplement what's there rather than try to tear out the seam. That's why I was asking about the sealing of butyl to butyl. Why isn't it used so much anymore?
Old 07-19-2018, 06:45 PM   #4
Rewards Points: 9,398
Re: Caulking
I took down some gutters at my mother's garage. They were sealed with a caulking that I believe was butyl. Certainly it was decades old, possibly original to the garage (>40 or 50 years). Caulking performed like it was put down the week before --- still tenaciously bonded, and extremely flexible and elastic.
As you noted, nothing will stick to cured silicone. I have never tried it, but have no reason to think new butyl would not stick to old butyl, so long as the old stuff is clean.
SPS-1 is online now   Reply With Quote
The Following User Says Thank You to SPS-1 For This Useful Post:
Tags
butyl , caulk , silicone , silicone caulk
Exterior Window Caulking Amitabh Windows and Doors 7 11-13-2012 11:37 AM
Bathroom floor/tub and caulking soulstar General DIY Discussions 5 11-10-2011 11:49 PM
caulking tile backsplash--he sprayed something on the caulking then used his finger Limit54 Tiling, ceramics, marble 6 12-06-2010 06:45 PM
Caulking Exterior Windows unixb0y Painting 1 06-04-2009 06:31 PM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 05:46 PM
