Caulk Or Grout Next To Cabinets - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-12-2010, 11:30 AM   #1
dIYHell
Rewards Points: 150
Caulk or Grout next to cabinets
Im finishing backslpash in my kitchen. I left a small gap 1/8" between my cabinet and the tile. I was intenting to caulk this line however is it possible to use grout for this gap instead to give a more consistent look?
rocketdoctor is offline   Reply With Quote
Old 01-12-2010, 12:50 PM   #2
Newbie Bill
Rewards Points: 534
You can get colored caulking.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 01-12-2010, 01:55 PM   #3
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
You can also get sanded color matched caulk to match the grout. You could put grout there but it will likely crack.
Last edited by Scuba_Dave; 03-04-2010 at 05:39 PM. Reason: removed advertising links
Brik is offline   Reply With Quote
Old 01-12-2010, 06:08 PM   #4
jlhaslip's Avatar
Rewards Points: 708
I usually place a 'light fill' of grout and then caulk with a Dow Corning translucent silicone. The caulk picks up the colour, the light grout doesn't crack, and if it does, the silicone seals anyway.
jlhaslip is offline   Reply With Quote
Old 01-13-2010, 10:55 AM   #5
dIYHell
Rewards Points: 150
Matching caulk and grout
Some of the Home Depot PolyBlend grout have matching silicon caulk (sanded and nonsanded). Whats even better is that HD only carried the nonsanded caulk in 2 white colors so it really limited the choice my wife has to make, which also are the same colors that match the thinset so it can hide some of the mistakes I made with getting thinset in groutlines
Old 01-14-2010, 08:03 PM   #6
Grout will eventually crack sooner or later, bad choice. Caulk this area. There are caulks in all colors both sanded & non sanded on the market.
infoskr is offline   Reply With Quote
Old 01-14-2010, 09:57 PM   #7
dIYHell
Rewards Points: 150
That's my plan in my previous post I mentioned how I found that there was matching caulk that ica use
Recaulking at previously silicone-caulked shower door frame hffeagan Kitchen & Bath Remodeling 37 06-05-2017 05:19 PM
Grout or Caulk? How? coolptnr General DIY Discussions 3 11-24-2009 10:09 AM
Grout or caulk shower? Joe Vieira Tiling, ceramics, marble 5 02-22-2009 10:42 AM
Grout before Caulk around bathtub? bsippl Building & Construction 6 08-19-2008 08:57 AM
Caulk over grout? Fulan Flooring 1 11-03-2006 07:44 PM
