Cathedral Ceiling Framing Questions - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-01-2009, 01:36 AM   #1
I'm building a 8' x 15' workshop. the roof is 8/12. would two 2x10s glued and screwed work as ridge beam? . also each 8' end wall has a 4' window on center. i'm planning to bring a 4x4 support post from beam to a 2x10 header supported by 4x4 trimmers. any suggestions?
I live in coastal northern California
bosox is offline   Reply With Quote
Old 08-01-2009, 07:20 AM   #2
Is the roof spanning the 8' width?
Are you planning on collar ties?
You say Cathedral ceiling - no rafter ties?
Without rafter ties every 4' then you need a structural ridge beam
CA may have stricter regs for earthquakes
Old 08-01-2009, 08:54 AM   #3
Hi,
A single ridge beam is enough. The rafters meet in the same spot. That is what holds them up not the ridge beam. They make Simpson hangers to tie everything together.
I would not put the window there. Put 2 windows in the wall or use sun tunnels for light.
What you are planning will work.
Leftyho is offline   Reply With Quote
Old 08-01-2009, 09:26 AM   #4
thanks for the replies.
the span is 8' with no ties at all - it's definitely a structural beam.
creating a cathedral ceiling Bob Mariani Carpentry 13 07-14-2009 06:27 PM
Supporting a cathedral ceiling jmpn Carpentry 4 06-01-2009 10:29 AM
Building Cathedral ceiling roof truss cdc1505 Building & Construction 3 05-06-2009 04:38 PM
How would you insulate this? Cathedral ceiling (scissor style) PICS Ininkus Building & Construction 13 02-19-2009 03:46 PM
